Powering a Sansamp Bass Fly Rig & a Fly Rig 5 on PP2+
Posted: Mon Dec 19, 2016 7:02 am
by dukeofwapping
Hello Voodoo Lab Gurus,
Would it be possible to power a Sansamp Bass Fly Rig safely on a a PP2+
It's rated at 9v at 200ma/Centre Negative
AND
A Fly Rig 5?
It's rated at 12v at 150ma/Centre Negative?
Yes, I AM using two Fly Rigs on the same board but they're being used for alternating between instruments. I really am not that greedy. But I AM in need of safe power. :)
Thanking you in advance.
Regards,
Andy
PS
Re: Powering a Sansamp Bass Fly Rig & a Fly Rig 5 on PP2+
Posted: Mon Dec 19, 2016 10:49 am
You can power both but you will need a Current Doubler Adapter (the one with the Green end) for the Fly Rig 5... the Bass Fly Rig will only need one of the included standard barrel cables.
You can power the Bass Fly Rig from output 5 or 6 with the corresponding DIP Switch set to Normal.
The Fly Rig 5 will use the Current Doubler adapter connected to any two of outputs 1-4 with the corresponding DIP switches set away from Normal together with one of the included standard barrel cables.
Posted: Tue Dec 20, 2016 3:51 am
by dukeofwapping
Hello Mr. C,
Thanks so much for your quick and detailed reply.
I just ordered a green tipped lead from your good selves to power up the FR5. The postage to the UK may be dearer than the cable BUT it'll be so worth it when it arrives. My pedalboard thanks you (as do I) in advance.
Kind regards,
Andy
JohnClark wrote:You can power both but you will need a Current Doubler Adapter (the one with the Green end) for the Fly Rig 5... the Bass Fly Rig will only need one of the included standard barrel cables.
