10 pedals/power mondo/ Need some advice.
Jason.Guitardude
Post by Jason.Guitardude » Thu Dec 08, 2016 9:54 am
Hi; I have the Mondo and I want to be sure about connecting the power for my Pedals on my pedalboard.
The pedals are:
Whammy 5
Vox/Joe satriani Big Bad Wah
Rat 2
Big Muff
Joyo Vintage Overdrive
Boss Ns-2
Boss EQ-20
Boss DD-7
Strymon-OB1
Strymon El capistan
Strymon Mobius
Strymon Big Sky
p.s
I have one more question; Does the Mondo have the Capacity to power my Infinity Looper if I wanted to?
Re: 10 pedals/power mondo/ Need some advice.
Post by JohnClark » Thu Dec 08, 2016 11:27 am
I count 12 or 13 pedals... is this a trick? ;)
The El Capistan, Mobius, Big Sky, and the Whammy 5 can each be powered from the High Current 9V outputs to the left.
The EQ-20 can be powered from either of the 250mA outputs (output 5 or 6 to the right) with the corresponding DIP switch set to Normal.
The rest of the pedals can each be powered from any of the remaining outputs to the right with the corresponding DIP switches set to Normal.
Since this will fill up the Mondo, the Infinity Looper will still use its included power supply connected to the Courtesy Outlet on the back of the Mondo. Otherwise it could be powered using our Voltage Doubler Adapter connected to both outputs 5 and 6 with the corresponding DIP switches set to Normal.
Jason.Guitardude
Post by Jason.Guitardude » Thu Dec 08, 2016 12:50 pm
Lol :lol: it's no trick!; Yeah I know it's a lot of pedals :)
I just want to say thank you so much :D you've made my day! now I can put my pedalboard together worry free! 8-)
Thank you Voodoo Lab Dudes for this support site;
and Thank you JohnClark you are most excellent!
Jason.Guitardude
Jason.Guitardude
Post by Jason.Guitardude » Mon Dec 12, 2016 11:22 pm
Hi again; I have everything set up now but I have a little problem;
My whammy 5 (270ma)
and my el capistan (250ma)
these are the only pedals left to hook up.
referring to the diagram in the users manual:
I have section (4) of the voodoo lab Mondo free and it shows 400mA for these 2 outputs;
is it combined for this section like it's combined in section (3) ?
or can I plug both of these in and it will be fine?
If not I'm going to probably have to plug my whammy into a small power bar or something.
Jason.Guitardude
