How to power my pedalboard with PP2+?
franrh81
Post by franrh81 » Wed Nov 30, 2016 12:26 pm
Im looking for a power supply and Im checking out the PP2+
This is my set up:
  • Ibanez TS9
    Boss Flanger BF9
    Boss Tremolo TR2
    Boss Reverb RV6
    MXR Phase 90
    Line6 Delay DL4
    DigiTech Whammy V
    TC Electronics Polytune
Re: How to power my pedalboard with PP2+?
Post by JohnClark » Wed Nov 30, 2016 1:15 pm
I don't know of a "BF-9", is the Flanger the BF-1, 2, or 3 perhaps?
The Whammy V can be powered from output 5 or 6 with the corresponding DIP switch set to Normal.
The DL-4 can be powered from output 5 or 6 with the corresponding DIP switch set away from Normal and will use one of the included cables with the one Red end.
The Polytune, TS-9, TR-2, RV-6, and Phase 90 can each be powered from any output with the corresponding DIP switch set to Normal.
franrh81
Post by franrh81 » Wed Nov 30, 2016 10:53 pm
JohnClark wrote:I don't know of a "BF-9", is the Flanger the BF-1, 2, or 3 perhaps?
Oh, i misstyped. I meant the BF-1.
So essentially I can run all my pedalboard with it? The Whammy V is AC as far i know.
Post by JohnClark » Thu Dec 01, 2016 11:12 am
Cool pedal! I dig those old chassis' from that era of Boss! The BF-1 will need to be powered from any one of outputs 1-4 with the corresponding DIP switch set away from Normal for "ACA" mode.
The Whammy 5 is actually is the first generation of Whammys to accept DC power anlong with the Whammy DT. It is generations 1-4 that require AC power.
