Powering a Boss Es-8
Posted: Fri Oct 28, 2016 4:25 pm
by iceman78
Ho, i got a mondo power supply and i'd like to know if i can power a boss es8 switching system. Someone can help me? Thanks
Re: Powering a Boss Es-8
Posted: Fri Oct 28, 2016 5:51 pm
Any of the High Current 9V outputs to the Left will work for this.
Posted: Thu Jan 04, 2018 10:42 am
by izdo89
Is this correct? From what I can find, the Boss ES-8 is AC and all the outputs on the Mondo are DC...
Posted: Fri Jan 05, 2018 11:19 am
Although Boss does refer to the supplied adapter as an "AC Adapter" (probably because it gets power from an AC mains wall outlet) the PSA series power adapter that comes with the ES-8 outputs 9VDC. The rear panel of the ES-8 says "DC In" above the power jack. ;)
The ES-8 takes 9VDC and draws just under 400mA. It can be powered from the ISO-5, Digital, 4x4, or Mondo Pedal Power models.
Posted: Thu Apr 12, 2018 4:50 am
by dipsilva
Can I power a Boss ES-8 with a Pedal Power 2 Plus?
Posted: Thu Apr 12, 2018 11:29 am
dipsilva wrote:Can I power a Boss ES-8 with a Pedal Power 2 Plus?
With a Pedal Power 2+ you would combine outputs 5 and 6, with their corresponding DIP Switches set to Normal, using a Current Doubler Adapter (the one with the Green end) together with one of the included all black standard barrel cables.
Alternatively, you could use the power adapter that came with the ES-8 and connect it to the Courtesy Outlet on the back of the Pedal Power 2+.
Posted: Tue Apr 17, 2018 4:26 am
by dipsilva
It helps a lot. Thank you.
