Powering a Boss Es-8
iceman78
Post by iceman78 » Fri Oct 28, 2016 4:25 pm
Ho, i got a mondo power supply and i'd like to know if i can power a boss es8 switching system. Someone can help me? Thanks
Re: Powering a Boss Es-8
Post by JohnClark » Fri Oct 28, 2016 5:51 pm
Any of the High Current 9V outputs to the Left will work for this.
izdo89
Post by izdo89 » Thu Jan 04, 2018 10:42 am
Is this correct? From what I can find, the Boss ES-8 is AC and all the outputs on the Mondo are DC...
Post by JohnClark » Fri Jan 05, 2018 11:19 am
Although Boss does refer to the supplied adapter as an "AC Adapter" (probably because it gets power from an AC mains wall outlet) the PSA series power adapter that comes with the ES-8 outputs 9VDC. The rear panel of the ES-8 says "DC In" above the power jack. ;)
The ES-8 takes 9VDC and draws just under 400mA. It can be powered from the ISO-5, Digital, 4x4, or Mondo Pedal Power models.
dipsilva
Post by dipsilva » Thu Apr 12, 2018 4:50 am
Can I power a Boss ES-8 with a Pedal Power 2 Plus?
Post by JohnClark » Thu Apr 12, 2018 11:29 am
dipsilva wrote:Can I power a Boss ES-8 with a Pedal Power 2 Plus?
With a Pedal Power 2+ you would combine outputs 5 and 6, with their corresponding DIP Switches set to Normal, using a Current Doubler Adapter (the one with the Green end) together with one of the included all black standard barrel cables.
Alternatively, you could use the power adapter that came with the ES-8 and connect it to the Courtesy Outlet on the back of the Pedal Power 2+.
dipsilva
Post by dipsilva » Tue Apr 17, 2018 4:26 am
It helps a lot. Thank you.
