It is currently Mon Jun 18, 2018 10:03 am
 Post subject: 400mA into 100mA?
PostPosted: Sat Oct 08, 2016 11:03 am
Can I safely power a pedal that's 9VDC @ 100mA by using a 9VDC @ 400mA connection on the ISO 5 pedal power, or will it hurt the 9VDC @ 100mA pedal?
 Post subject: Re: 400mA into 100mA?
PostPosted: Tue Oct 11, 2016 9:36 am
No problem at all!
A pedal will only draw the amount of current it needs to operate so it is perfectly safe to power a low current draw pedal from the High Current output on the ISO-5.
PostPosted: Tue Mar 28, 2017 2:43 pm
Good to read that this works, but it seems that for me, pedals that draw 9VDC @ 100mA aren't drawing any power from the 9VDC @ 400mA output (though they seem to be drawing from the other 9V outputs just fine). Is this a common problem? Do I need to be running a different type of cable?
PostPosted: Thu Mar 30, 2017 9:47 am
No sure why that would be... what power supply are you using? What pedals are you using?
