What VL cables do I need for these pedals/etc.?
loveguitar
Post by loveguitar » Thu Oct 22, 2009 9:16 pm
Many thanks in advance if someone can reply. I need to know which cables to use for each pedal/device. I bought a VL Pedal Power 2 used, but there were only a few cables included.
Rat Pro-Co Distortion
Boss DD-3
Barber Tone Press
Ernie Ball Stereo Volume Pedal
Line 6 DL4
EH Deluxe Memory Man (classic older version)
Boss DD-20 Delay
Boss TU-12 Chromatic Tuner
Re: What VL cables do I need for these pedals/etc.?
Post by JohnClark » Tue Oct 27, 2009 12:23 pm
Except for the DL-4, all of these should be able to be powered using the standard barrel connectors. The possible exceptions would be the Rat and the Memory Man... (if you can find a power jack on the EB volume pedal, let me know ;) )
The Rat might have a 1/8" (3.5mm) mini plug connector and the Memory Man might have the same or even a captured AC cable which would connect to the Courtesy Outlet on the back of the Pedal Power.
The DL-4 will require the Red ended Barrel connector and will have to be powered from output 5 or 6 with the DIP switch set away from Normal. The DD-20 should be powered from output 5 or 6 with the DIP switch set to Normal. All the rest should be powered from any output set to Normal.
