Courtesy plug and timline
Tommymx01
Post by Tommymx01 » Mon Jun 13, 2016 7:08 pm
I know I here people using the voltage doubler I was wonder could you use the courtesy plug on a power plus 2 with the actual Strymon power source ?
Re: Courtesy plug and timline
Post by JohnClark » Tue Jun 14, 2016 9:56 am
No problem at all to use the original power supply connected to the Courtesy Outlet.
p.s. It's the Current Doubler that that people are using to power from the front outputs. Never use a Voltage Doubler with any Strymon pedal! ;)
nozkcb
Post by nozkcb » Wed Jun 29, 2016 10:39 am
JohnClark wrote:No problem at all to use the original power supply connected to the Courtesy Outlet.
Same here. I use the Courtesy Outlet on my 2 Plus, and my Timeline has been working perfectly since I put it on the board years ago.
