PP2+ w/ Sennheiser Wireless
foomanfat
Post by foomanfat » Thu Oct 08, 2009 6:10 pm
Is there a way to power a Sennheiser ew172 G2 wireless system with a PP2+?
Re: PP2+ w/ Sennheiser Wireless
Post by JohnClark » Mon Oct 12, 2009 11:29 am
I am not sure... It may work from output output 1-4 switched away from normal if it requires less than 100mA (probably unlikely) or perhaps outputs 5 or 6 switched away from normal if it requires less than 250mA. Sennheiser says that the receiver power requirement is "10,5 - 16 V DC battery AA (Mignon)" which does not really tell the whole story. Does the receiver have a power supply for it? If so, what are the output specs listed on the power supply itself?
foomanfat
Post by foomanfat » Tue Oct 13, 2009 4:32 pm
The wireless requires 12v, but 300mA.
Post by JohnClark » Wed Oct 14, 2009 10:09 am
Where did this info come from? If that is what the output of the power supply is then it is not really the requirement but a working scenario. The stated requirement is "10,5 - 16 V DC" as specified in the manual. Unfortunately there is no current draw mentioned.
What does all this mean?... It likely means that you can use output 5 or 6 with the DIP switch away from Normal. Try it out and let us know what you find. Be sure to find, and mind, the correct polarity for the pedal!
