Powering 4x4 from Power Plus 2 Courtesy Outlet
ZiZO
Post by ZiZO » Wed Sep 02, 2015 1:50 pm
Hi guys,
I'm new here, however I've been using my Pedal Power Plus 2 for years now. I am very happy with my PP2 but as my pedalboard grew I have now run out of outputs. I have tried daisy chaining the dirt section and it works fine without noise but the daisy chain cable limits my pedals arrangement and is causing me a lot of inconvenience.
I am considering purchasing a 4x4 as I could benefit a lot from its high current outputs. I know I can use the courtesy AC outlet in PP2 to power an AC pedal like the Digitech Whammy for example, but can I power the 4x4 from this courtesy outlet to save plug space? Has anyone tried this? Is it safe and noise free? I assume that the courtesy outlet is supplying an AC voltage similar to what I am plugging into which is 220V in the UK but I need to know for sure before I try it out.
Thank you all very much and I apologise if this has been asked before. I look forward to your feedback.
Cheers now,
Z
Re: Powering 4x4 from Power Plus 2 Courtesy Outlet
Post by JohnClark » Wed Sep 02, 2015 2:07 pm
You can power any model of Pedal Power from the Courtesy Outlet with no problems.
The Export model Pedal Power 2+ has a Reverse IEC Jack that mates with an IEC Extension Cable.
ZiZO
Post by ZiZO » Wed Sep 02, 2015 2:09 pm
JohnClark wrote:You can power any model of Pedal Power from the Courtesy Outlet with no problems.
Jeez that was quick!!!
Hahaha, fantastic, thank you very much for your help John, I really appreciate the quick reply.
Cheers buddy :D
