radial tonebone classic and PP2
pitzend
Post by pitzend » Thu Sep 24, 2009 1:16 am
I have a radial tonebone classic that runs on a 15vdc supply. What is the best way to power this pedal if at all with the PP2? Can I use output 5 or 6 with the dip switch on? Or could I get a Y-adapter and run use outputs 7 and 8 with them adjusted at 7.5 volts each using the dip switch on function?
Re: radial tonebone classic and PP2
Post by JohnClark » Fri Sep 25, 2009 9:32 am
The Tonebone Classic can not be powered from the front panel outputs. The documentation states that it requires 15V @ 400mA! You can run it from the Courtesy Outlet on the back of the Pedal Power 2 using the supplied adapter.
