It is currently Fri Jan 19, 2018 8:27 am
 Post subject: Pedal Power and X2 XDS-Plus
PostPosted: Mon Sep 07, 2009 11:36 am
Can the PP2+ power a X2 XDS-Plus wireless receiver, using one of the L6 outputs with the DIP-switch set to ON?
According to the specs the XDS-Plus needs 9V / 300 mA. A pro rackbuilder states that using output 5 or 6 on the PP2+ with the DIP-switch set to ON (resulting in higher voltage and higher amperage) works without any problem. I'd be happy with that but I need confirmation.
If so, does this also work with the PP2 (not the Plus)?
 Post subject: Re: Pedal Power and X2 XDS-Plus
PostPosted: Mon Sep 07, 2009 12:50 pm
I'll answer my own question: yes it does!
I set the DIP-switch on output 6 on a PP2 (not a Plus) to ON. It may not be 9V, it may not be 300mA, but the X2 XDS-Plus runs without problems!
If it works with a PP2, it'll probably work with the PP2+ as well.
Users browsing this forum: No registered users and 11 guests
