Voodoo Lab
Wireless recievers?
http://www.voodoolab.com/forum/viewtopic.php?f=7&t=43
Author:  skibob [ Tue May 12, 2009 2:28 pm ]
Post subject:  Wireless recievers?
Just wondering... Can the Pedal Power 2 Plus safely power a Shure PGX4 wireless receiver?
The power reqs for the PGX says 12-18Vdc at 150 mA. The PP2P would also be running a couple of distortion pedals, like a TS9 and an OCD.
Thanks...
Author:  Josh Fiden [ Tue May 12, 2009 10:29 pm ]
Post subject:  Re: Wireless recievers?
This should be okay from outputs 5 or 6 with the DIP switch set away from normal.
**NOTE: Check the polarity on the power supply, this may be center positive! You need to verify this and then use a reverse polarity cable.
Because all Pedal Power 2+ outputs are isolated, you can power devices that require either polarity by using the correct cable.
Please post your results, thanks!
Regards,
Josh Fiden
Founder / CEO
http://www.phpbb.com/
