Empress Superdelay and EHX Micro Pog?
pete
Post by pete » Tue Jul 21, 2009 4:40 pm
Can I power both of these pedals with a PP2? The Empress is 9-12v at 300mA while the EHX is 9v at 200mA.
Re: Empress Superdelay and EHX Micro Pog?
Post by JohnClark » Fri Jul 24, 2009 9:43 am
You should be able to power both of these pedals from the Pedal Power 2+. If you actually have a Pedal Power 2 (not +), then these will be right at the limits and may behave strangely.
The Superdelay should be powered from output 5 or 6 with the DIP switch set away from Normal. The Micro POG should be powered from output 5 or 6 with the DIP switch set to Normal.
