It is currently Wed May 22, 2013 12:13 am
 Post subject: Help please !!! power my pedal board
PostPosted: Mon Apr 30, 2012 4:09 pm
I own a digitech whammy, a DL4 and MM4 from line 6, a pog2 from eletroharmonix, a tu3 and ns2 from boss, a joyo vintage overdrive, a wd-7 from ibanez and a handmade volume pedal that consumes 21mA. I can run ALL my pedals on a PP2+ ???? My biggest doubt is about the POG2
 Post subject: Re: Help please !!! power my pedal board
PostPosted: Fri Jun 22, 2012 5:42 pm
To power all from a single Pedal Power 2 Plus, you will need a Current Doubler Adapter (part# PPAP) and an Output Splitter Adapter (part# PPAV), setup as follows:
To power your Line 6 DL4 use Pedal Power 2 Plus outputs 5 or 6, DIP switch AWAY from NORMAL and the reverse polarity cable (red/black connectors) supplied w/ your Pedal Power 2 Plus (part# PPL6).
To power your Line 6 MM4 use Pedal Power 2 Plus outputs 5 or 6, DIP switch AWAY from NORMAL and the reverse polarity cable (red/black connectors) supplied w/ your Pedal Power 2 Plus (part# PPL6).
To power your POG 2 use a Current Doubler Adapter (part# PPAP, $6.00ea.) in any two Pedal Power 2 Plus, DIP switches set NORMAL and one of the all black (standard polarity) cables supplied.
To power your TU-2 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
To power your NS-2 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
To power your Joyo Vintage Overdrive use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
To power your WD-1 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
handmade volume pedal that consumes 21mA. - Likely the same as the Boss pedals but that's just my guess.
The Whammy (models: Whammy WH-1, Whammy XP-100, Whammy II, Bass Whammy, Whammy IV and 20th Anniversary) requires AC power and cannot power from the DC outputs of your Pedal Power 2 Plus. However, you can use the courtesy outlet to power your Whammy with its adapter. Note: Pedal Power AC can power your Whammy.
You can order our cables and adapters online.
To do so, please visit our Cable Purchase web page.
Here is the link: http://www.voodoolab.com/shop/index.php?cPath=22
