It is currently Fri May 24, 2013 4:00 pm
 Post subject: Pedal Pwer 2+ cables..cannot afford to get this wrong !!
PostPosted: Sun Mar 11, 2012 12:12 am
Hi guys, I am building my first pedal board and seeking your experience and confirmation that I am using the right cables and output ports.
1. Carl Martin Octa Switch 2.
2. Peterson Stomp Classic Tuner.
3. CAE - Custom Audio Electronics Wah
4. Rothwell Love Squeeze Compressor.
5. Ibanez TS808 Keeley Mod Tube Screamer
6. EHX Deluxe Memory Man (24 v DV).
7. TC Electronic Stereo Chorus / Flanger (AC Powered)
8. Demeter Stereo Tremulator TRM 2S.
After reading all the manuals and some experimentation, here is what I am hoping is right.
1. Carl Martin Octa Switch 2 - Use Port 5 (high current) with a reverse polarity cable (Centre Positive) Barrel 5.5mm x 2.1 mm connector. Dip switch on NORMAL.
2. The Tuner - Any port 1 - 4 , 9v dip switch normal, supplied centre negative 5.5 x 2.1mm barrel cable .
3. The Wah - Any port 1 - 4 , 9v dip switch normal, supplied centre negative 5.5 x 2.1mm barrel cable .
4. Rothwell Comp - Any port 1 - 4 , 9v dip switch normal, supplied centre negative 5.5 x 2.1mm barrel cable .
5. Ibanez TS808 - Use the supplied adaptor cable with centre positive (tip) 3.5mm mini plug.
6. EHX Memory Man - POrts 1 & 2 using the volt doubler cable, Dip Switches set away (for 12v x 2 = 24V), Centre positive.
7. TC Electronic Chorus - supplied integrated AC cable.
8. Demeter Tremulator - Pedal POwer 2+ supplied Centre Positive 3.5 mm mini plug.
Does anyone see any problems where I might blow up an effect ... cannot afford to...:-)
