Pedal Power 2+ Questions
coot tone
Post by coot tone » Thu Jul 16, 2009 9:26 pm
Regarding the SAG controls, what direction do you turn the knob to get the full 9 Volts, clockwise, or counter clockwise (when looking at the unit with the outlets underneath the SAG control).
Is there an easy way or trick to get to the SAG controls after the PP2+ has been mounted to a Pedaltrain?
Re: Pedal Power 2+ Questions
Post by JohnClark » Fri Jul 17, 2009 10:29 am
The Sag controls are activated once the DIP switch is set away from Normal for outputs 7 and 8. Turning the Sag Counter-Clockwise lowers the voltage.
If you pedal board is covering the Sag controls then you will likely need to pull the Pedal Power off the board to set the Sag how you like, then re-mount the Pedal Power.
