It is currently Fri Apr 20, 2018 1:52 am
 Post subject: Earthquaker Devices Disaster Transport + PP2
PostPosted: Fri Feb 03, 2012 1:40 pm
I have been using for a while a PP2 and today I received the Earthquaker Devices Disaster Transport delay pedal. The power requirement of this pedal is 9v with a negative center. The matter is that I already used the 1-5 outputs. Is it fine to use the #7 or #8 outputs to power this pedal? It's a digital delay and I don't intend to use the SAG properties. Thanks in advance.
 Post subject: Re: Earthquaker Devices Disaster Transport + PP2
PostPosted: Tue Feb 07, 2012 1:04 pm
I don't see a current rating for this pedal, but you can certainly try it in any output with the corresponding DIP switch set to Normal. If it draws more than 100mA then you will have to power it from either output 5 or 6 with the DIP switch set to Normal.
cron
