Buffer (T1m mini buffer),9v low mA.To power your Buffer use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Dunlop Cry BabyTo power your Cry Baby (95Q) use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Boss TU-12 TunerTo power your TU-2 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Diamond CompressorTo power your Diamond Compressor at 24VDC use a voltage doubler cable (part# PPY $6.00ea.) in any 2 of Pedal Power 2 Plus outputs 1-4 with their DIP switches set AWAY from NORMAL.
Boss OD-1 OverdriveTo power your OD-1 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Boss SD-1 Super OverdriveTo power your SD-1 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Boss Distortion OS2To power your OS-2 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Boss OC-2 OctaverTo power your OC-2 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Boss CE-5 Chorus EnsembleTo power your OS-2 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Mutron III To power your Mu-Tron III use any 2 Pedal Power 2 Plus outputs, DIP switches set NORMAL and a voltage doubler cable (part# PPY $6.00ea.). Also, the original Mu-Tron III had an unusual 3-Pin power jack. To power the original model use 2 battery snap cables in any 2 outputs DIP switches NORMAL. Or, use the AC courtesy outlet with the Mu-Tron III power adapter.
Digitech T7Having trouble finding this one. Does it have a more complete name.
Roland Space EchoTo power your RE-20 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Flashback DelayTo power your TC Flashback use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
Hall of Fame ReverbTo power your TC Hall of Fame use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
GE-7 Graphic EQTo power your GE-7 use any Pedal Power 2 Plus output, DIP switch set NORMAL with one of the all black (standard polarity) cables supplied.
