It is currently Thu May 23, 2013 4:45 pm
 Post subject: Daisy chaining multiple Pedal Power units
PostPosted: Mon Jan 02, 2012 3:40 pm
Hello and Happy New Year!
I'm running a Pedal Train Pro and have a few Pedal Power units mounted underneath to power everything. I just received my Pedal Power Digital today to power my Strymon pedals and was a bit disappointed to see that there is no courtesy outlet on the unit to be able to power the Pedal Power AC and Pedal Power 2+ that are already on the board. This mean that to avoid having to use a separate power cable to power it, I'll have to mount the Digital as the last power supply in the chain (I'm using 6" IEC cables to keep everything neat.
My question is: will the Digital's power quality end up suffering if I go from outlet -> Pedal Power 2+ -> Pedal Power AC -> Pedal Power Digital?
Why did you not include an AC outlet o n the Digital? :(
Anthony
 Post subject: Re: Daisy chaining multiple Pedal Power units
PostPosted: Tue Jan 10, 2012 1:05 pm
No problem whatsoever in doing this. It is perfectly acceptable to chain these three power supplies together using the Courtesy Outlets found on the other two units. In fact, you can power 10 more Pedal Power units after the first one before you come close to the stated 200Watt max on the Courtesy Outlet.
One of the power supplies had to be last in the chain... we just made the decision for you! ;)
Voodoo Lab ®
Tech/Magician
