It is currently Wed May 22, 2013 4:19 am
 Post subject: Empress SuperDelay & Strymon Bluesky with PP2+?
PostPosted: Sun Dec 25, 2011 9:34 am
Just wondering if this is possible? I understand you can simply connect the Strymon Bluesky to output 5 OR 6 set to normal and it will work fine, however The Empress website states this:
Q: Will the Super Delay work with Voodoo Lab Pedal Power?
A: Yes. You can power the Empress Superdelay from outputs 5 or 6 of the Voodoo Lab Pedal Power 2+. You'll need to use the red barrel connector. You must set the corresponding DIP switch away from the NORMAL position. Also, since the Superdelay requires nearly 300mA, you should only use the other output for a much lower current pedal.
So does this mean I can't connect the Bluesky to output 5 or 6 aswell as the Empress Super Delay? what would I have to do in this situation.....thanks and Merry Christmas!
 Post subject: Re: Empress SuperDelay & Strymon Bluesky with PP2+?
PostPosted: Tue Dec 27, 2011 4:39 pm
anybody?
PostPosted: Thu Dec 29, 2011 7:51 pm
Actually you can power both.
Dip switches in normal 9V position - off. Combain output 4 and 5 with double current cable for blueSky and for Superdelay use double current cable for output 6 and 7. This will give you 350mA for each unit (Superdelay requires nearly 300mA, and blueSky requires 250mA). But be careful with Superdelay, because it's center positive so you need to use the red barrel connector at the end of double current cable while blueSky it's center negative (standard Boss type)!
Who the f**k is Mr. VonTone?
PostPosted: Wed Jan 25, 2012 1:03 pm
To power your Empress Superdelay use Pedal Power 2 Plus output 5 or 6, DIP switch set AWAY from NORMAL and a reverse polarity cable (white/black connectors part# PPREV $3.50ea.). Or, use the courtesy outlet with the adapter supplied with your Empress Superdelay.
To power your Blue Sky use Pedal Power 2 Plus output 5 or 6, DIP switch set NORMAL and one of the all black (standard polarity) cables supplied.
PostPosted: Tue Mar 20, 2012 2:47 pm
Can you power a Blue Sky with Pedal Power 2 (I know you can with the 2+)
