It is currently Tue May 21, 2013 2:13 pm
 Post subject: Strymon pedals
PostPosted: Thu Dec 15, 2011 2:57 pm
Hello,
I just bought a PP 2+. Can I use it to power my Strymon OB.1 compressor, or do I need to use the PP Digital?
Anthony
 Post subject: Re: Strymon pedals
PostPosted: Fri Dec 16, 2011 1:12 pm
You can power the Strymon OB.1 from any output on a Pedal Power 2+ with the corresponding DIP Switch set to the Normal position.
Voodoo Lab ®
Tech/Magician
PostPosted: Sat Dec 17, 2011 3:23 pm
Thanks John.
Which Pedal Power model should I use to power the Orbit, Ola, and Timeline? (all Strymon pedals). I want to make sure I buy the right one. I'm assuming the PP Digital? Will that power all 3?
Anthony
PostPosted: Wed Dec 21, 2011 1:35 pm
Either one, Pedal Power 2 Plus or Pedal Power Digital can power the Strymon Timeline, Orbit, Ola and OB1. To do so with Pedal Power 2 Plus will require 2 Current Doubler Adapters (part# PPAP). If these are the only pedals you need to power, Pedal Power Digital may be the way to go but if you need to power additional 9VDC pedals (not high current), or need the AC courtesy outlet then you may wish to use Pedal Power 2 Plus.
If you choose Pedal Power 2 Plus:
To power your Timeline use a Current Doubler Adapter (part# PPAP) in Pedal Power 2 Plus outputs 4 and 5 (or 6 and 7), DIP switches set NORMAL and one of the all black (standard polarity) cables supplied.
To power your Ola use Pedal Power 2 Plus output 5 or 6, DIP switch set NORMAL and one of the all black (standard polarity) cables supplied.
To power your Orbit use any 2 Pedal Power 2 Plus outputs, DIP switch set NORMAL with a Current Doubler Adapter (part# PPAP) and one of the all black (standard polarity) cables supplied.
To power your OB1 use any Pedal Power 2 Plus output, DIP switch set NORMAL and one of the all black (standard polarity) cables supplied.
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
