It is currently Fri Feb 23, 2018 1:37 am
 Post subject: Power supply setup
PostPosted: Tue Nov 08, 2011 5:08 pm
So i've finally got my pedal board and i'm in the process of trying to economize my setup. As of now i have a PP2 plus powering 6 effects:
Boss TU-3
Keeley 4knob Compressor
Electro Harmonix Octave Multiplexer
Boss Fz-5
Rockbox Boiling Point
xotic EP booster
all of the above are normal 9v pedals which means i have 2 extra outputs on my PP2 plus. What i'm currently doing for all the other pedals is running a power strip from the PP2 plus for all their adaptors. Those pedals are as follows:
Digitech EX-7 expression factory
Maxon RTD800 overdrive/distortion
Eventide Modfactor
Strymon Timeline
Strymon BlueSky
It would be nice to eliminate the power strip and all the adaptors and hook them up to a Pedal Power Digital. Since it has only 4 outputs, i need to know if i can use the 2 outputs i have left on the PP2 plus to power any of those. (likely either the maxon or the digitech)
 Post subject: Re: Power supply setup
PostPosted: Tue Nov 22, 2011 6:29 pm
Your Digitech Whammy and EX-7 require AC power and cannot power from the DC outputs of your Pedal Power Digital (or Pedal Power 2 Plus). However, you can use the courtesy outlet to power your Whammy and EX-7 with their adapters. Note: Pedal Power AC can power your Whammy and EX-7.
So, you may still need some type of power strip/extension cord.
To power your Maxon RTD800 use a Pedal Power Digital 9VDC output with a standard polarity 2.1mm cable. Or, to power your Maxon RTD800 use a Current Doubler Adapter (part# PPAP, $6.00ea.) in Pedal Power 2 Plus output 5 and 6, DIP switches set NORMAL and one of the all black (standard polarity) cables supplied.
PostPosted: Tue Nov 22, 2011 10:06 pm
That's a feasible solution. Thanks Rez :D
