Powering the Option 5 Destination Rotation w/PP2 (24v)
radioscooter
Post by radioscooter » Sat Jul 11, 2009 10:17 pm
I have an original PP2 (not plus) and also an original purple Option 5 Destination Rotation(not single vibe) that takes 24v. I was just looking at the stats for the newer PP2+ and they say that a cable can be obtained to run 2 outputs together and switch them to run at 24v.
My question is can the original PP2 do this? I would love to have all pedals on one supply and this one is currently eating up a 24v hotspot wart.
Thanks for the help in advance
Re: Powering the Option 5 Destination Rotation w/PP2 (24v)
Post by JohnClark » Mon Jul 13, 2009 10:48 am
Because the outputs are isolated, all of the DC Pedal Power models can use this cable. For 24v from an original Pedal Power you can use any 2 outputs switched to "off". For 24v from a Pedal Power 2, or 2+ you can use any two outputs 1-4 switched away from normal.
