It is currently Mon Jul 23, 2018 8:23 am
Post new topic Reply to topic  [ 10 posts ]
 Post subject: voodoo lab power 2 + and H&K???
PostPosted: Sun Jun 14, 2009 9:16 am
Hi everyone!
I just buy that pp2 + and i want to connect Korg Dt-10 (9V), Boss DS-1 (9V), Boss HR-2 (9V), Boss CS-5 (9V)
AND H&K TubeFactory and H&K Rotosphere. how do i connect these...mmm...that those work best? Do i put those 9V pedals to 1-4 and H&K´s to 5 and 6 or what? please help me.
 Post subject: Re: voodoo lab power 2 + and H&K???
PostPosted: Sun Jun 14, 2009 10:10 am
Site Admin
The Hughes & Kettner Tube Factor and Rotosphere both require 12VAC at high current. You can power their supplied adapters from the AC line out on the back of the PP2+ or the Pedal Power AC can power them both.
This is a very typical power requirement for vacuum tube pedals. 12AX7 filaments alone require 150mA each, they often draw a little more. If the input power is AC (instead of DC) it is very easy to derive the high voltage for the plate supply, either with a transformer or a voltage multiplier circuit.
Josh Fiden
Founder / CEO
PostPosted: Sun Jun 14, 2009 12:08 pm
Thank you for reply.
it was very...tecnical info. could you make it simple for me please?
so can i connect my H&K´s to pp2+ 1-4 slots and turn the DIP (bottom) ON or Normal? Or same thing 5 or 6? and those 7 & 8 was other purposes. that i know ;)
I don´t understand those AC,DC,ACV,ACA things? and that DIP is also little ???
And i have a 14 cables.
3 are other end red and other black
1 is for battery
1 is for Dod, voodoo lab, mxr etc.
9 are just black, but 7 was littlebit differend.
but what cables i use?
PostPosted: Sun Jun 14, 2009 12:32 pm
Site Admin
The PP2+ only has DC outputs. The H&K pedals require AC. They cannot be powered by the DC outputs of the PP2+. You must use the H&K adapter that came with them.
Your other pedals can be powered from any output 1-8, with the switch in the NORMAL position. Use the black cables. Most of the black cables have right angle ends, but since these will not fit all pedals, 2 have a straight end.
If that is not clear, please post a specific question.
Josh Fiden
Founder / CEO
PostPosted: Mon Jun 15, 2009 12:51 am
hello and thank you. that was clear :)
so, now only i have to do is find that right cable, so i don´t need to buy anotherone pedal power. is it that red one? i didn´t have any info about cables, because i buy´it pp2 + used.
PostPosted: Mon Jun 15, 2009 1:03 am
iip.
now i think i understand. there is no way to connect those H&K´s to pp2+
i readed those pp2 & 2+ cables info. so it was waste of my money. :(
but that pp2 ac is not enough for me, and two pedal power devices seems to be too much for me.
PostPosted: Sat Jun 20, 2009 7:26 pm
juhimuskeli wrote:
iip.
You need to plug the H&K adaptor into the back of the Pedal Power, not the front.
Connoisseur of good tone.
http://www.guitarpedals.co.nz
PostPosted: Mon Jun 22, 2009 10:13 am
Has no one suggested the Pedal Power AC to this gentleman?
PostPosted: Mon Jul 06, 2009 4:23 am
What i can input left power slot back at PP2+??? that 200watts max? and how? can i put PP2AC power cable to that or???
PostPosted: Mon Jul 06, 2009 9:09 am
Site Admin
The Pedal Power AC requires less than 40W. Yes, you can plug it into the PP2+ AC out.
Josh Fiden
Founder / CEO
Users browsing this forum: Google [Bot] and 1 guest
