need a cable!!
bigmike
need a cable!!
Post by bigmike » Sun Sep 26, 2010 6:05 am
I have a pedal power 2 plus lab and am currently using 9 boss pedals. any idea where I can get some sort of splitter cable to run two pedals into one jack on the lab?
bigmike
ninzanstudio
Re: need a cable!!
Post by ninzanstudio » Fri Oct 01, 2010 11:06 am
bigmike wrote:I have a pedal power 2 plus lab and am currently using 9 boss pedals. any idea where I can get some sort of splitter cable to run two pedals into one jack on the lab?
bigmike
bigmike,
You can get a Y-split adapter from a Voodoo Lab dealer (such as myself) or from Voodoo Lab directly. It's basically a short Y cable (about 3"-3.5" long) with a 5.5x2.1mm plug that goes into a power port and splits into two cables each with a 2.1mm female jack. You can attach any length 2.1mm tipped cable you'd like to these jacks. The only caveat is that the two pedals to be powered off this adapter must have a direct audio path between them (ie, the audio cable from the output of the 1st pedal goes into the input of the second pedal), because of the lifted ground on one of the legs. I found that this adapter comes in super handy when using smaller power supplies such as the ISO-5.
