Boomerang III Phrase Sampler + PP2+
sigitar
Post by sigitar » Sun Aug 29, 2010 6:00 am
Hi!
Can I power up the Boomerang III Phrase Sampler with PP2+.
And - if yes - how?
thanks!
Jon Wilder
Re: Boomerang III Phrase Sampler + PP2+
Post by Jon Wilder » Sun Aug 29, 2010 11:45 am
sigitar wrote:Hi!
And - if yes - how?
thanks!
The Boomerang Phrase Sampler III calls for an adapter that can source a minimum of 700mA. With a current doubler adapter, then PP2+ can source only 500mA at most. Because of this, more than likely it cannot be powered via the PP2+.
Jon Wilder
Voodoo Lab
Tech Support
ninzanstudio
Post by ninzanstudio » Mon Aug 30, 2010 9:14 am
I modified PedalTrain Mini (FuelTank Chameleon power supply underneath) for a customer from France who requested this pedal in his signal chain. He confirmed from Mike at Boomerang that 500mA 9vDC will work.
"Mike said DC 9V 500mA is fine."
We ordered a custom parallel Y cable (current doubler) from Voodoo Lab and his Boomerang works fine.
Post by JohnClark » Mon Aug 30, 2010 10:47 am
What Mr. Wilder didn't know when he answered this is that we have actually had the Boomerang III here for testing and have confirmed that it in fact does work with the Pedal Power 2+ when using the Current Doubler cable on outputs 5 and 6 switched to the Normal position.
ninzanstudio
Post by ninzanstudio » Mon Aug 30, 2010 10:51 am
JohnClark wrote:What Mr. Wilder didn't know when he answered this is that we have actually had the Boomerang III here for testing and have confirmed that it in fact does work with the Pedal Power 2+ when using the Current Doubler cable on outputs 5 and 6 switched to the Normal position.
Awesome! Thanks for confirmng this John.
wnembangsubba
Post by wnembangsubba » Sat Apr 22, 2017 8:59 am
Hey John,
I know this is an old post. I just bought a Boomerang III and have been using VL PP2+, Mondos and 4x4 for ages. Great products by the way. I am combining the current from output 5 and 6 from my PP2+. I was just wondering what cable would I use to go from the current doubler cable to the Boomerang III pedal, as a regular connector doesn't fit. The red-to-black (reverse polarity) one does fit, but just want to confirm before using it. Also is it true that the difference between a pedal that takes reverse polarity versus a regular pedal (with voltage, current and everything else being constant) is just the size of the hole? Thanx.
Wabun
Post by JohnClark » Mon Apr 24, 2017 9:57 am
The Red ended cable is the correct one to use here. http://www.voodoolab.com/shop/index.php ... taitp7kf31
There is no direct correlation between the polarity and the jack size/type used in guitar pedals. However, a 2.5mm jack is most commonly used on devices that take AC power. This pedal happens to accept AC or DC power.
