It is currently Wed May 23, 2018 11:50 am
 Post subject: AC Courtesy Outlet???
PostPosted: Tue Jun 02, 2009 6:51 pm
Hello,
Can I plug in a 12V 300mA digital pedal into this AC Auxiliary outlet??? Would it draw what it needs? or would it damage my pedal?
DC outlets 5 and 6 are almost suitable but don't quite meet the required 300mA for this specific pedal.
Sean
 Post subject: Re: AC Courtesy Outlet???
PostPosted: Wed Jun 03, 2009 1:08 am
Plugging into the Courtesey Outlet as you descibed will be fine. It was designed for applications like these.
Connoisseur of good tone.
http://www.guitarpedals.co.nz
PostPosted: Thu Jun 04, 2009 9:31 am
How difficult it would be to rotate the courtesy outlet 180 degrees?
PostPosted: Thu Jun 04, 2009 8:02 pm
It sounds like you're trying to power a ND1 or something the likes of TC Electronics. The AC outlet on the PP2 will do it for sure. Outputs 5&6, with the DIP switched away from normal are also supposed to be able to put out this kind of power. I talked to John @ VL and he said they'd had LOTS of success with it.
Good Luck....
Nick
PostPosted: Mon Jun 15, 2009 1:59 am
Will the AC courtesy outlet power the Digitech Timebender? I think it's 9VAC 1.3 amps.
PostPosted: Mon Jun 15, 2009 4:38 am
Yes all you are doing is utilising the adaptor that came with the pedal. Should be fine no problems.
