KR MegaVibe
Xchekker94
KR MegaVibe
Post by Xchekker94 » Sat Jun 19, 2010 11:58 pm
I've thoroughly searched the forum and have not been able to find anyone else who has asked how to set up the PP2+ to run a KR Musical Products MegaVibe. The pedal is expensive and takes a long time to get after placing an order so I don't want to make an expensive mistake.
On the PP2+ setup, the only thing I know for sure is that I need to use a white reverse polarity cable which I've already ordered and received. What I don't know is what setting to use or which output to plug the MegaVibe into. The wall-wart adapter that comes with the MegaVibe has a center positive 12vdc and 200ma max output.
So the question I have is do I use outputs 1-4 with the dip-switch set away from NORMAL or do I use outputs 5-6 with the dip-switch set away from NORMAL?
Thanks for your assistance!
Re: KR MegaVibe
Post by JohnClark » Tue Jun 22, 2010 11:56 am
The KR Musical Products Megavibe can be powered by the Pedal Power 2+ using output 5 or 6 with the DIP switch set away from Normal.
monkeyboyuk
Re: KR MegaVibe
Post by monkeyboyuk » Mon Jan 09, 2017 7:06 am
Hi John,
I have a Mini Mega Vibe Pedal. Can this be powered from the Mondo?
Input: 120V AC 60Hz 5W
Output: 12V DC 200mA
It's got a US plug but I am based in UK, therefore the mains power is 240v. Am presently using a very buzzy adapter so would like to use the Mondo if possible!
Is there a cable I can buy to connect the pedal to the AC outlet?
Thanks in advance for your advice.
Re: KR MegaVibe
Post by JohnClark » Wed Jan 11, 2017 1:57 pm
monkeyboyuk wrote:Hi John,
On a Mondo you would use either of the High Current 12V outputs for either model of the KR Megavibe.
