Right voltage output for EHX Hum Debugger
DeeKnow
Post by DeeKnow » Wed Apr 15, 2020 6:52 pm
I've used one of the SAG outputs in my Pedal Power 2 Plus unit for my EHX Hum Debugger which requires 7.5 volts 400 mA to run - I dialed the output back, the pedal powers up, but doesn't cancel hum in my Telecasters - BTW, it works fine with the factory supplied AC adapter. I considered plugging the adapter into the AC outlet in the back of the unit but I'm using a Pedal Train Classic Jr and there's not enough space for the adapter to access the input with the unit installed under the Pedal Train...suggestions ? Attach a shorty extension from the unit to the adapter? Easiest solution would be run the Hum Debugger direct from the Pedal Power - but how to I get 7.5 v and 400mA? Suggestions? Thanks. Dean
Rez
Re: Right voltage output for EHX Hum Debugger
Post by Rez » Mon Apr 20, 2020 5:16 pm
As Hum Debugger requires AC power, it cannot be power from the Pedal Power DC outputs.
However, you can power it from the AC courtesy outlet with its adapter/wall-wart.
Cheers!
Cheers,
Ben Resnick
Voodoo Lab - Tech Support
