Akai Head Rush
DeeKnow
Akai Head Rush
Post by DeeKnow » Wed Apr 15, 2020 5:04 pm
Hi, there - wondering which output on my Pedal Power 2 Plus I should be using for my Akai Head Rush Delay - the ac adapter lists the output at 9 v DC 200 mA...so far I've used output 7 with the DIP Switch set at normal, seems to work ok - any suggestions would be appreciated - thnx. Dean.
Re: Akai Head Rush
Post by Rez » Mon Apr 20, 2020 5:14 pm
Although it's working, it may be under-performing too (due to its needing higher current).
To power the Akai Head Rush Delay with Pedal Power 2 Plus, use output 5 or 6, DIP switch in the 9V (normal) setting.
