PP2+ Voltage Question
JimmyWilliams
Post by JimmyWilliams » Fri Apr 03, 2020 8:19 am
Hey everyone,
I'm trying to figure out if I will run into any voltage problems by using outputs 5 & 6 on the PP2+ for the two pedals listed below. I am currently powering a Two Notes CAB M on output #5 with the dip switch set to "on", thereby utilizing 12 VDC. I am wondering if I can power the KSR Ceres on output #6, leaving the dip switch in the "normal" position at 9 VDC. I think I can but any help is greatly appreciated. Thanks.
Voltage Requirements for each pedal:
Two Notes CAB M - 12 VDC / 200 mA
KSR Ceres - 9 VDC / 200 mA
Jimmy
Re: PP2+ Voltage Question
Post by Rez » Mon Apr 06, 2020 2:33 pm
Yes, it's perfectly fine and precisely as you've described.
JimmyWilliams
Post by JimmyWilliams » Tue Apr 07, 2020 6:14 am
Great, thanks!
Post by Rez » Tue Apr 07, 2020 11:42 am
