PP2+Ojai+ HXstomp
sbatch28
PP2+Ojai+ HXstomp
Post by sbatch28 » Sat Sep 21, 2019 11:40 pm
I’ve got a PP2+ as my main power supply and I add a strymon ojai connected into the courtesy outlet to expanded power and outlets.
I’m thinking to get an HX stomp as modulation/I can do all pedal but I’m not sure i’ll be able to power it properly.
I was thinking to use 2 of the ojai outputs juiced from the PP2 courtesy outlet ...any experience /suggestion if this may work safely?
Re: PP2+Ojai+ HXstomp
Post by Rez » Mon Sep 23, 2019 10:11 am
As long as the 9VDC outputs (on the Ojai) are isolated and have a capacity of at least 500ma, I expect it will work fine. And, certainly it's fine to power the Ojai from the Pedal Power AC courtesy outlet.
Also, we build a custom cable for powering the HX Effects/Stomp... you'd likely need that too. To order the custom cable, please, call us or send an email, to: info@voodoolab.com.
sbatch28
Post by sbatch28 » Mon Sep 23, 2019 10:33 am
Thanks...I will do as soon as I buy it!!
Post by Rez » Mon Sep 23, 2019 10:37 am
Right on ;)
