PPL6 vs PPREV for reverse polarity
tintin
Post by tintin » Fri Jun 07, 2019 10:29 am
I just bought a Fulltone '69 pedal, and I'm uncertain which power cable to use with the PP2+. According to Fulltone I should use a reverse polarity cable, but Voodoo Labs has 2 different ones - #PPL6 and #PPREV. I already own the PPL6, so it would be great if I could use that one. It fits the pedal, despite being 2.5mm. Anyone have experience with this?
Re: PPL6 vs PPREV for reverse polarity
Post by Rez » Fri Jun 07, 2019 11:59 am
The PPL6 can also be used, but... the 2.1mm Reverse Polarity Barrel Cable, part# PPREV, PPREV-R is the better option as its 2.1mm white end makes a more snug connection with the 2.1mm pin in the pedal's power jack (whereas the PPL6 red end fits 2.5mm).
tintin
Post by tintin » Fri Jun 07, 2019 12:55 pm
Thanks, Rez! Sounds like it’s safe to use the red one until I get a #PPREV.
Post by Rez » Mon Jun 10, 2019 9:38 am
Yes indeed!
