Hilton active volume pedal
Agapi2302
Post by Agapi2302 » Mon Apr 01, 2019 5:17 am
Hello
Q1.
I as wondering if i can use my pedal power 2+ to power a Hilton active volume pedal.
It uses a 24v with 0.625A power supply (DC current).
If not is there any other pedal power from voodoo lab that is able to do so?
Q2. Silly question. Is it possible to power a digitech whammy pedal (it needs a 9v ac power supply) using the outlet of power2+ ?
Thank you
Re: Hilton active volume pedal
Post by Rez » Mon Apr 01, 2019 11:26 am
Yes.
To power the Hilton Volume Pedal with Pedal Power 2 Plus, use a Voltage Doubler Adapter, part# PPAY in any two of outputs 1-4, DIP switches set AWAY from normal and with a 2.1mm Reverse Polarity Barrel Cable, part# PPREV, PPREV-R.
And, yes it's fine to power the Whammy (AC model) from the AC courtesy outlet with its adapter/wall-wart.
