Pedal Power 2 PLUS courtesy outlet
Baladaddy-
Post by Baladaddy- » Mon Apr 01, 2019 4:56 am
I run my pedals on a Pedal Power 2 PLUS and used up all 8 outputs and a friend of mine gave me a strymon ojai recently and i was wondering if i was able to power the ojai though the 2 PLUS. The ojai has a Strymon STR-PS124 power adapter/power brick that needs to be plugged into a wall if its the ojai is not being powered by another strymon pedal. Am i able to connect a cable form the outlet of the 2 PLUS to the strymon power adapter to power my ojai?
Re: Pedal Power 2 PLUS courtesy outlet
Post by Rez » Mon Apr 01, 2019 11:30 am
Yes, it's fine to use the Pedal Power AC courtesy outlet, as you suggest (to plug-in the adapter to power the Ojai).
