Pedal Power 2 Plus with Line 6 M5
Posted: Sat Mar 16, 2019 4:06 pm
by estiv
I'm creating a new pedal setup and wanted to include a Line 6 M5. One reason I bought the Pedal Power 2 Plus was because I saw that it can work with some Line 6 products. However, I can't get the M5 to work using the supplied Line 6-compatible power cord. I did make sure to put the switch in the non-9V position. I know a POD wouldn't be compatible, but is the M5 also incompatible? If so, which Line 6 devices are compatible? Thanks in advance for any help.
Re: Pedal Power 2 Plus with Line 6 M5
Posted: Mon Mar 18, 2019 10:33 am
by Rez
Due to its high current requirement, a single output will not suffice...
To power the M5 with Pedal Power 2 Plus, use outputs 5 and 6, DIP switches set normal with a Current Doubler Adapter, part# PPAP and one of the all black (standard polarity) cables supplied.
Cheers!
Posted: Tue Mar 19, 2019 9:30 pm
by estiv
Thanks for the detailed explanation, I’ll give it a shot.
Posted: Fri Mar 22, 2019 2:43 pm
by Rez
Posted: Sat Mar 23, 2019 3:59 pm
by estiv
Worked perfectly. Thanks again.
Posted: Mon Mar 25, 2019 9:46 am
by Rez
Awesome and glad to know it, thanks!
