It is currently Sat May 25, 2013 12:21 am
 Post subject: Pedal Power 2 Plus + EHX Microsynth & Mark Bass Compressore
PostPosted: Sun Apr 29, 2012 4:39 pm
I've been using the front outlet to power my EHX Bass Microsyth, but the addition of the Mark Bass Compressore had me search for other options. I found a thread that says "The Micro Synth can be powered from any two of outputs 1-4 on a Pedal Power 2+ switched away from Normal using our EH24 cable." viewtopic.php?f=7&t=1197
Which cable is that?
Then can the Compressore be power from the main outlet? says (700mA minimum)
 Post subject: Re: Pedal Power 2 Plus + EHX Microsynth & Mark Bass Compress
PostPosted: Mon May 07, 2012 2:47 pm
The EH24 is a voltage doubling cable, and can be found here... http://www.voodoolab.com/shop/index.php?cPath=22_24_32 ...the one in the middle, with the single Red end is the EH24 cable.
The Mark Bass Compressore cannot be properly powered by the front outputs on a Pedal Power 2+, but you can power it from the Courtesy Outlet using the supplied adapter.
Voodoo Lab ®
Tech/Magician
PostPosted: Mon May 07, 2012 5:04 pm
Thanks! I've ordered the EH24.
How much can be powered from the courtesy outlet? Could I power both pedals until the adapter arrives?
PostPosted: Thu May 10, 2012 2:23 pm
The cable arrived today, but isn't working.
The red end is loose in the pedal. Almost like it's the wrong size. Is that the problem?
PostPosted: Thu May 10, 2012 3:46 pm
Are you sure you have the 24V version of the Bass Micro Synth?
Voodoo Lab ®
Tech/Magician
PostPosted: Fri May 11, 2012 6:40 am
CRud! That's the problem. It's the 9V, but it says 'not to daisy chain'. I thought I had tried wiring it regularly in the past and it didn't work. Or someone told me not to. I guess I'll try that.
PostPosted: Fri May 11, 2012 9:12 am
The 9V Bass Micro Synth should be able to be powered from output 5 or 6 on a Pedal Power 2+ with the coresponding DIP switch set to Normal using one of the all black barrel cables.
Sorry for the confusion. Feel free to contact us about getting a refund on the cable EH24 that you don't actually need.
Voodoo Lab ®
Tech/Magician
